Re: wiper diagram
I do have the schematics in the haynes manual I have. It shows ground going to the switch pole, but when switched on that pole, they should go to positive. Today I hooked up just the motor without the pulse board and the motor just make a click sound and then all the wires go to positive. So I believe that the motor is bad. The new one will be in tomorrow so I will try it. If not I think I will just throw molotov cocktails at the car until it explodes.
david said:you can not fix a electrical problem with out a electrical diagram purchase a repair manually with electrical diagrams and follow the diagrams for powers grounds and switch. if you can't understand a wiring diagram than its over your head and you need to hire or find a friend that does, on the internate alldata or mitchell on demand have diagrams but they will cost you i have a gm manual for a 84 buick i can see if i can find it and help you if you can get some kind of wiring diagram
