I've had pretty good luck with the one person bleeder method- gravity bleed to start the siphon, hang the bottle higher than the caliper, slowly pump the pedal, then close the bleeder.
Hey everyone ,
Two more questions, do the Blazer and the S10 use the same spindles, and when you upgrade to the blazer spindle does it push your wheels out or does the track stay the same.
Thank you in advance .
Looks good. How bad does it rub?
