I guess I should have measured. The swap is done on my car and if there is a difference it's not evident to the naked eye.
If it gives you a wider track it will have a better chance to rub on the sway bar and the plastic wheel housing in the back on full lock. The F body spindles I use put the wheels out about 1/2" on each side and that was noticeable on a full lock
