body mount bushings : rubber or urethane
bigdan
380
4
st-jean baptiste ,quebec,
I'm at the point of changing my body mounts bushings....
both, urethane and rubber mounts are available ...
pros & cons of both would be apreciated ....
does the urethane reflects the vibrations into the body or is it a mith?
I want the car to handle but not at the point of hearing all types of squeals and noises ...thanks
Dan
Silent viewer
1,445
142
i bought a set of energy suspension bushings but i hae not installed yet. after seeing the ones i removed from my cars and every other g body i have had my hand in working on the rubber ones seem to be junk but thats just what i have seen.
Lue
868
Los Angeles, california
Dan
I'm glad that you ask this question, cause i have heard the same about urethane. But i have also heard that they last longer than rubber.
shotgun
1,067
80
48
Nort o Philly
I have installed poly on a min. of 10 cars with no issues.
You may hear noise from poly when used in your suspension (if not properly lubed) but I never heard a thing from body bushings.
If they are moving around that much you gots other issues!!
Just did a 64 Tempest Convertible, only non stock parts were the poly body bushings and sway bar bushings.
If they were going to squeak,it would be on a rag top.
Car feels real solid and just floats down the road, no nioses.
Lue
868
How about engine, and transmission mounts?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
for the body mount bushings if your on a tight budget you can use hockey pucks...
shotgun
1,067
80
48
Nort o Philly
Never use a trans mount that is stronger then your engine mounts.
Example,rubber engine,poly trans is no good.
Poly engine and rubber transmission is fine.
I use one poly on the driver side engine mount,rubber on passenger and poly trans on cars that see any street use.
Best of both worlds,more control with very little vibration.
