Brake/Tail Light Socket Replacement
Tynan918
1,136
249
1984 Monte Carlo..
My drivers side pair of brake/tail light sockets are bad.
The top socket doesn't work at all, and has 4 wires running from it...
The bottom socket works with some adjusting but not long, and has only 3 wires...
I bought a new 3 wire socket, and I'm looking for another but can't find one...
What is the difference between the two different socket wiring ?
Tynan918
1,136
249
The four wire is likely worn out from someone putting the wrong bulb in it or forcing a bulb in it backwards. Look down the grooves (RED ARROW) in it and compare the the new socket you have if those are worn the contacts on the bottom of the bulb wont press hard enough on the two metal contacts in the bottom of the socket, Those contacts also act like springs to keep it all tight might bend those up some.
Also make sure the ground terminal is not bent back where it is not solidly against the brass ring around the base of the bulb. (BLUE ARROW)
I would test the 3 wire socket out with a meter and make sure it is getting grounded, has voltage etc. before changing it.
I was looking for this diagram...
What cleaning solevant works best to clean those connections/brass...it's dirty more than anything...
ELCAM
1,124
1,270
A small piece of sotchbrite pad and a pair of hemostats to knock that heavy stuff off, then some non flammable brake cleaner or just alcohol nothing harsh it will melt the plastic.
Tynan918
1,136
249
I bought CRC..
Well, after cleaning the 4 wire socket, I noticed the 4 wire bulb was loose and I folded a piece of electric tape over a couple of times to wedge the bulb down and to the contact points...
Problem fixed...😎👍🏾🎯‼💯
