Learn something new everyday. I have a 86' BRF in my 86' Monte, don't recall knowing there was any difference. Guess I could of had lockup in 3rd all this time if I put some effort into it. Oh well.
What are you using to control the lockup?Learn something new everyday. I have a 86' BRF in my 86' Monte, don't recall knowing there was any difference. Guess I could of had lockup in 3rd all this time if I put some effort into it. Oh well.
Depending on how you control the lockup you may need to change the switches, the factory switches are NC ( normally closed) and open when trans engages that gear.Learn something new everyday. I have a 86' BRF in my 86' Monte, don't recall knowing there was any difference. Guess I could of had lockup in 3rd all this time if I put some effort into it. Oh well.
The reason i asked is the CZF (white 3 pin) plug will go in the BFR trans socket (black 4 pin) but it will only go in 180 degrees out (upside down). The locking tab on the sockets is at the top on both, if your plug is plugged in with the locking clip on the bottom its upside down see pics.I just plugged in the stock wiring, same that was on the CZF trans and original to my 86'. Still running the CCC Q-Jet and ECM (although changed to a 87/88 ECM and ZZ4 PROM). I don't recall the plug being different in any way, I did the swap to the built BRF trans back in 2013.
Plug is keyed by the pins not the locking tab and will only go in 1 way into the socket.I'll try and look this weekend. The TC locks up, the trans was also rebuilt, the plug orientation could of been changed theoretically(?). I'll report back with what I find.
