dogsh1t
Poly will not make them harsh or transmit drone to your ears and numbness to your arse. Thats what hockey pucks and aluminum blocks are for.
dogshit said:Poly will not make them harsh or transmit drone to your ears and numbness to your arse. Thats what hockey pucks and aluminum blocks are for.![]()
KrisW said:I use poly mounts and bushings everywhere except the rear control arms. I cannot explain it, but it makes my car "buck" sometimes when I hit a curve at speed. For those, I use heavy duty rubber, like the "Del-a-lum" bushings. I have seen other guys use rod ends and eliminate that problem too.
But everything else, poly.
KrisW said:You can buy the poly mounts from TA performance. They are supposed to fit either the V6 or the 350. I am assuming maybe that the mount has the holes elongated where the through bolt goes. They are on my list to purchase but I don't have them yet.
TA V1822D
I went through a similar ordeal with my 78 Firebird, years back. I put in a 340 from a 67 LeSabre, it fit perfect, but I had to use the V6 mounts which I tore also. I have heard that you can buy the poly set, and then just replace the one side that always tears with the poly, leaving the other side that gets compressed as original rubber. I will probably just do them both, I am not worried about harshness.
