Now you are ready for the drip rail trim. Start at the top and rotate it down into position by snapping it in place under the roof.
Your next trim piece will be the wide B pillar trim.Make sure that then you install it you lock the little tab on the drip rail trim behind it. You will also want to seal this piece to the body with strip caulk or foam weatherstripping tape. Unfortunately, I didn't take any pics of this step.
Now you are ready to start installing the weatherstripping channels. Start by putting a big wad of strip caulk in the corners. This will seal the joint of the two pieces, as well as make up for the gap where the foam tape will not bridge the gap at the bend in the main channel that bolts to the roof and A pillar.
Now, you will need to use the foam tape to seal the channels before you install them. Put the tape a little in from the edge so it is concealed when you bolt this all together and it does not squeeze out. The channels themselves have a little indentation where the factory put it's tape. Follow them and you will be fine. (bad pic of this step as it was done at 2am)
I will complete this how to later. I have to go catch up on homework right now.
![l_2a88dd25028f4b2f83c5785e1785f256.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fc3.ac-images.myspacecdn.com%2Fimages02%2F31%2Fl_2a88dd25028f4b2f83c5785e1785f256.jpg&hash=8d3819ad14825f3c6dd86b7424cc577a)
![l_9e66b4a2dc8f464f8f9a573bbc048623.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fc4.ac-images.myspacecdn.com%2Fimages02%2F50%2Fl_9e66b4a2dc8f464f8f9a573bbc048623.jpg&hash=0e5f4f2736559739f4a1c7446d692aeb)
![l_a016097a42bd4c28932fc50e9f900096.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fc3.ac-images.myspacecdn.com%2Fimages02%2F33%2Fl_a016097a42bd4c28932fc50e9f900096.jpg&hash=c71e383d5314d90e83bbe8e0bea15804)
![l_7332a738033346e69958511aa5594e7d.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fc2.ac-images.myspacecdn.com%2Fimages02%2F48%2Fl_7332a738033346e69958511aa5594e7d.jpg&hash=457f2ce76a2e5febf32cc5f7392a62af)
