Meh . . . couldn't wait until tomorrow though, since it is after midnight, I guess I still sorta waited until tomorrow . . .
Got one side scattered already. Yeah, I know, don't scatter the other side until you reattach this one . . . well, unless you want a REALLY big surprise on your hands . . .
Though the suspension is completely different components, I've already been through this on my 2002 Tacoma. New Boss COs up front, new Deaver J59 Leaf Packs, HD Bilsteins, and Firestone air bags in back so I already know the dos and don'ts of suspension swaps. Um . . . I think?
I have a little rust removal and touch up to do before I can put on the PURDY parts. That will likely take [later today] plus dry time so I may not get this side back together today. I may see if I can go ahead and put the UMI Pro-touring sway bar on while I am watching paint dry. Haven't looked but I am just guessing that could/should be the last thing to go on but I'll take a look. Or, I can certainly start putting on my rear hitch bracket to tie those rear frame rails together . . . that should work OK.
I started by just removing the shock, then popped the factory spring and spacer out. I [like the first month I owned the car] ripped out those worthless factory air shocks and [to get the same stance] put in a 1" spacer and HD Monroes [about the best shock you could buy 30 years ago]. MUCH better rear suspension performance over the air shocks [in 30 years ago terms!]
And all gone [except the upper control arm]
Outside view [need to remove rust on the coil mounts and rear lower control arm mount and re-coat]
