Just more feedback on stuff I am using . . .
Not sure I can recommend this product. Being a 3 step process, I assumed it would be more thorough but I'm not very impressed. Naturally, it has a 5 star rating.
1) The degreaser KLEAN product works pretty decent but certainly no better than many others I have used and not as good as some.
2) The etching rust remover BLAST doesn't do much at all. Even tried some full strength. Oh, it does some good, just not much.
3) The sealer SEAL [duh?] is supposed to be satin, not gloss, but it is pretty high gloss. Since my previous pic was when it was still tacky wet, I assumed it would tame down some when dry but it is still high gloss.
4) The sealer is not bonding at all. Probably partly due to the BLAST stage not working very well but it is like putting on a coat of rubber. When you get a chip [like the UMI lowering bracket did to my lower CA mount] you can just peel all that sealer off in big chunks. Even where there was no rust, it isn't bonded to anything but itself.
Short of dropping the entire rear end and having it bead blasted and powder coated . . . Anyone got a better idea?
Just a good cleaning and regular ole Rustoleum would be better than this . . . me thinks.
