Cam Questions
78sik ick
34
30
So I bought my Regal with a built 383 and am in the process of putting on some Brodix heads. I found the cam specs for the Motor and gave them to my buddy at the machine shop who looked at them and said, oh its pretty mild. My Regal sounds like a drag car and pulls like a Rap*** ape, went side by side a cbr600 to 100.... the Hydro roller cam specs are
Intake Valve Lift (in.)0.540
Exhaust Valve Lift (in.)0.562
Int. Duration @ .050 in. (Deg)242
Exh. Duration @ .050 in. (Deg)248
Int. Duration Advertised (Deg)294
Exh. Duration Advertised (Deg)300
Is this really that mild of a cam or is he just yanking my chain so to speak?
Serious for a street motor, not so much for a track-only car.
A 294/300 degree duration advertised, is a 2500rpm to 7200rpm cam. He either wants it, or he wants to sell you one, or both. YES, IT'S A SCREAMER!! ANNNNND IT'S A ROLLER. LOCK UP THE NUMBERS. If you're jackin with a sport bike, why did you take it apart?? :roll:
It had some super ported iron heads and got a set of brodix heads for super cheap that my buddy is gonna cnc for me and needed the cam specs for the head build to make sure I wouldn't run into coil bind or valve float
