hello i have a 88 monte ss i took out the original 305 engine and swapped it with a 350 with mild comp cams and lifters and high volume oil pump edlebrock 600 carb, and a holley street dominator intake with the stock distributor cap rotor and the factory coil from the 305 . the car will not start at all it cranks and cranks but will not start as if the timing is off 180. but the firing order i checked over an over an its right as i read on the computer 1-8-4-3-6-5-7-2 clockwise with the copper strip on the rotor facing my number one cylinder and my number one wire on the cap is at the bottom right facing the front right side of engine. while cranking it act as if it trys starting with my dstributor cap twist more to the rear of the firewall but then i get a backfire out the carb sometimes its just gas sputtering out an sometimes its alittle flame then goes out ... can someone help me with this thanx alot
