Can’t figure out what is wrong with cutlass
ELCAM
1,007
1,053
blacknchrome
13
If the plugs are covered in carbon it is running rich.
Make sure the choke is working properly.
Check float adjustment.
Will check float adjustment tomorrow. The electric choke has a broken thermostat since July, so it currently doesn’t do anything. I did get a replacement in the mail today, so I’ll be putting that on this week.
blacknchrome
13
I think I may be on to something now. After reading that article you shared, I decided to go look at the specs on the fuel pump I installed. It’s listed as 7.5 - 9 psi. I don’t believe I have a fuel regulator installed, so I think the carb is getting too much fuel.
64nailhead
Goat Herder
5,530
11,705
Upstate NY
The electric choke is broken. What does that mean exactly? If the choked staying closed all of the time?
I'd STRONGLY recommend to STOP changing parts for no rhyme or reason. Figure out what is wrong before you change or do anyting else.
If the choke is staying closed all of the time, then that's your problem. But everything you've done so far doesn't make sense other than the replacement of the plugs.
blacknchrome
13
The end of the coil in the choke broke, so it doesn’t engage on cold starts. It just stays in the open position.
64nailhead
Goat Herder
5,530
11,705
Upstate NY
If this is an electric choke on a Holley carb, then that is the opposite of how it should work. It should be closed all of the time rather than open. It could be flopping around from closed to open at will if the spring is broken in multiple locations. But it should start god awful if the choke is stuck open.
Is the choke moving around at will, stuck open or stuck closed? A picture or two of what is going on with this choke with would be worth a 1000 words.
Regardless of your answer, you should resolve this prior to anything else being done IMO. Do you know how to set an electric choke on a Holley?
LeftLaneOnly
282
480
You can also pull the air filter off start it up and put your hand over the carb to act as a choke it should rev up with your hand over the carb.
if it does work on your choke.
blacknchrome
13
I’m just at work now but will get some photos later tonight. The choke seemed to be stuck open, I’m not too sure if it closes. My father in law knows how to set the choke, so as soon as I can see him he is going to help me get that on.
64nailhead
Goat Herder
5,530
11,705
Upstate NY
It’s not hard, actually it’s really easy. Just has to be put on correctly.
The car should pretty bad, if at all, with the choke stuck open until it gets to operating temperature.
