shotgun said:Are you 100% sure that you got the right belt with the right pitch?
If the belt is right , put a lite coat of Hi- tack on the grooves in the pulleys, will never slip again.
well when i spray the spray belt dressing into the groove on the crank it will stop the squeeking for that time the car is running but on next startup it will squeel again
so my first move i think should be clean up the groove (because the crank pulley has been painted black) and then maybe get some good belt squeel stuff (suggestions?) and hope for the best
