87chevyboy said:pontiacgp said:the 2.43 which I think is a 2.41 is a 2nd series and the 3.73 would be a 3 series carrier. The 2 series goes down to 3.08 then from 2.23 on is a 3 series. So basically you'd have to do it by the first method I mentioned. Also a limited slip is the same thing as a posi
my bad i meant its the 1 tire spinner![]()
your were sorta right...your rear end is limited to spinning only one tire...
