Ecnes said:DrRansom442 said:Ecnes said:quick question people im new to this forum but im trying to do the same thing to a stock olds 350 im my 79 cuttlass and was looking in to the vortec heads and tighter valve springs idea and was wonder for my 350 what kind of car can i find 350 vortec heads to swap and what size would the valve springs need to be in order to get a lil more power?
If you can find some early 330 (#4) or 350 (#5/6/7 heads) .... find a competent porter that knows what an Oldsmobile IS! Discuss a port, three angle job and possibly larger valves ... but even in stock form the stock chambers will boost compression. This needs to be mated with the RIGHT cam choice for maximum effects. Got any ideas on the grind?
so its not as easy as just throwing some heads on. and the wreckers here in the bay area suck! cant find sh*t for gbodys really. and if u do its an arm and a leg to buy. is there an idea on wat kinda vavle springs i sld jus put on my stock ones for now? im jus tryin to get the most power posible without having it sit forever.
Well, it can be. It just comes down to if you want to get the most gain out of changing heads while they are off. If you find a used set of heads, they will most likely need rebuilt. Might as well have a three angle valve job done, resurface them, replace valve springs, replace guides. If you read up on the internet, you can find info on what type of porting needs done on Olds heads to get the most gains and you can probably do it yourself if you have the tools.
Sorry for the dumb question, where is the bay area, east or west coast? I am retarded when it comes to any locations out of Ohio :lol: You will not be looking for these heads out of a g body. They would be in 60's and 70's cars. If you join some Olds specific forums, you will be able to find a set of early heads from a member for a decent price. They usually go from $75 to $150 for a set that needs rebuilt. You may be able to find a set that are ready to go, but that would be more money.
Also, how much more power are you trying to make? With these engines, the best way to make more power is to raise compression by changing pistons and replacing the cam. The heads may give you a sight power increase, but it may not be a real noticeable gain. It won't hurt changing heads now, and when you are ready, pull the engine for a rebuild. That way, when you get the engine rebuilt, you won't have to worry about the heads. If you want a real noticeable gain in performance, change the gears to a higher ratio.
