OK, long story short, I wiped out the cam and four lifters in my Cutlass two weeks ago. I decided to pull the engine for a complete rebuild.
Current setup
3970010 block, four bolt mains
Stock, cast iron crank
Stock rods
Bored .030 over
Flat top pistons with four valve reliefs
462624 heads with 2.02/1.60 valves
Old school Holley street dominator intake
Edelbrock 600 cfm Carb
Unknown cam
The engine will get new rod, main, and cam bearings, new rings, and ARP bolts for the rods and heads.
I have a set of Trick Flow Kenny Duttweiller 195cc aluminum heads that will be swapped on, 195cc intake runners, 64cc combustion chambers, 2.02/1.60 valves, Trick Flow 1.5 ratio aluminum roller rockers
I am looking at a Comp Cams 280h cam, .480/.480 lift and 230/230 duration @ .050
Looking to run around 9.5:1 - 10:1 compression
What do you guys think? The engine is already out and at the machine shop, will be ordering parts in the next few days.
Current setup
Stock rods
Bored .030 over
Unknown cam
