I looked into Pin#42 from my Camaro schematics and it is the same Fan#1 control as a truck 411 PCM, so it should work.
The PCM will complete the ground path for cooling fan relay #1 under any of the following conditions:
• When engine coolant temperature exceeds 105°C (221°F).
• When A/C is requested and ambient temperature is greater than 10°C (50°F).
• When A/C refrigerant pressure is greater than 190 psi (2 volts).
Should be able to program that with HPT pretty easy.I have the fans running separately so when PCM calls for low only one fan runs when the PCM calls for more cooling the second fan kicks in. Something I was thinking was to have the second fan run during the compressor cycle and then if the temp climbs to 190 then the first fan would join in
Let me get to the house and I'll snap a pic of how my fans are tuned in HPT. I'm running aftermarket fans, but controlled by the ECM. Mine are only on/off though and not low/high, and I'm not running AC.I have the fans running separately so when PCM calls for low only one fan runs when the PCM calls for more cooling the second fan kicks in. Something I was thinking was to have the second fan run during the compressor cycle and then if the temp climbs to 190 then the first fan would join in
