Test for continuity from the sensor body to both terminals. Then, test for continuity across the 2 sensor terminals. Then, test the 2 terminals as the engine warms up.
By polarity I mean that the sensor is isolated from the body, allowing it to be used for 12v instead of ground. Your light/gauge wires should both need ground. If neither terminal has continuity to the sensor body, you need to ground one of the terminals to make the sensor work.
