- Dec 26, 2013
- 12,489
- 113
That was my post (Temp Light on Dash), where I show pictures of the temp switch for the ECM and connector. My ECM is located over on the passenger front fender well. Good luck. I have a different issue, where I see the single blade temp sensor coming out of the front passenger side of the engine, but can't seem to find the wire to connect it to. My temp dummy gage light inside the care pulses, never off or never fully displayed.Someone else asked a similar question recently. It seems to me that someone else remarked that there are two different sender units, one that gives info to the ECM, and one that goes to the gauge. The single blade sender should screw into the side of the head, either between 1& 3 on the driver side, or 6 & 8 on the passenger side, depending on your wiring harness (oops, forgot that you have the v6, but should still be in the head).
Search other threads for a more definitive answer.
The two wire style is mounted at/near the water neck.
