Door hinges and Pop rivets. I love it !!
Looks like you hit an air bubble in the casting.
Weld it up and start over!!
. I've done about a 70% solution on these - which will yield a 90% result for flow. That last 30% of effort will take as long as the first 70%....
Mike, that's why I chose to go with the 862 heads I pulled from a Suburban in the yard. They are essentially the same as the 706, just a different casting number. They flow great for a stock head, and should do well on my 5.3 with the dished pistons and boost.Mind officially blown. http://www.hotrod.com/articles/surprising-hp-numbers-stock-ls-cylinder-head-test/
I knew the 706 heads were good for a production head - but, not this good. May have to reconsider using 241s on the 4.8L. Plus, the 1.89" valves are lighter than the 2.00"+ units which can impact valvetrain stability at high RPM.
