Anti-party pullies for alternators are a thing now:
7,989
18,702
Pretty interesting. My truck regularly sees 6k+ RPM. I wonder what the corresponding alternator RPM is? 🤔 I'll have to do some measuring. I do have an underdrive crank pulley though. That would have been another way for him to address the issue but it is a lot more A$$ ache to change, obviously. I'm on my third alternator that shows some "pulsing" of the lights. I've attributed this to the somewhat inconsistent idle speed associated with the cam, but maybe not.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
There is a much easier fix...
Install and Olds motor. Itll never happen again, and you'll be safer not being able to go 130mph in the 1/8. Plus all the torques in the midranges.
81cutlass
4,650
13,577
Western MN
I wouldn't worry unless you're consistently spinning faster than a LS7 Z06 redline
Unless there's something special with those?
I frequently do.
I believe there are different designs among GM alternators. The one on my TBSS is clutched.
Ma
Now what? That's interesting knowledge there, does it clutch out at higher RPM's? My fear with all the extra electronics we add is running out of juice, especially at high RPM.
I believe it is designed to freewheel off throttle. It's referred to as an overrun/decoupling pulley. Same idea as the pulley on my Hellcat's supercharger. Keeps the rotors from going out of time after a power pull and slamming the throttle shut. It is a passive design.
Different than this.
mad max GIF
But, protects under harsh conditions.
Here's some more information:
The weather was back above freezing and sunny. So the door was opened and we got ready to party.
Always a sketchy process getting it up on the wheel cribs.
But once it is up, it is solid. The circulation space is a welcome change... even if my spoiled @ss wants the lift installed.
Now I need to fix a couple of rotted body mounts, a couple of soft spots in the rear seat pan, and do some rust repair to the lower front and rear quarters. Then as time allows I will get the car ready for safety and maybe start the actual bodywork.
Reactions: 13 users
scoti
1,986
3,423
Texas
I thought about building the cribbing to be able securing them to a set of wheel dollies. Once you get it set-up on them, then you can roll it around for shop maneuverability (shove it one way or the other to allow additional work space on the side you're focusing on).
