cruise control
mugzi
132
when i disconnect my cruise my throttle response is lazy
why. what should i do.
dan2286
2,233
4
Cleveland, Ohio
What did you disconnect on the cruise control?
Sep 1, 2006
6,687
33
Tampa Bay Area
It should have nothing to do with it unless you are disconnecting the vacuum lines. They run to the servo and the brake pedal switch.
mugzi
132
i replaced my shift cable off the 200 r4 but i disconnect everything form the cruise and block everything up. but i cant remember what goes into that that black round canister and the other one thats right by it.
Sep 1, 2006
6,687
33
Tampa Bay Area
What round thing, the cruise control servo or the vacuum storage ball?
mugzi
132
one is a ball and the other is a canister.
dan2286
2,233
4
Cleveland, Ohio
The canister is for the evap system, the ball is the vacuum storage unit.
The evap gets hooked to the gas tank and the carb. It should say what line goes where on top of the canister.
I dont know what gets connected to the vacuum storage unit.
Sep 1, 2006
6,687
33
Tampa Bay Area
The vacuum storage ball is in the vacuum lines for the HVAC flapper door controls. Disconnecting it would make it hard to operate the ventilation controls. It also helps to add a buffer to the cruise control system too.
