CS130 Alternator, 3 wire plug and 2 wire Idiot Light install...
How can I wire this 2 wire idiot light to my CS130 alternator ? I've been trying to decode this wiring setup/route for 4 hot days now...
Idiot light has two wires running from it, brown and black.
Alternator has a 3 wire plug, and on it the wires are labeled "SFLP" (P has no wire.).
I'm told: "S" wire goes to the alternator battery stud, F isn't used if I'm using the idiot light, "L" is wired to the idiot light power wire (brown), and there is no wire for "P" on the plug."
I have the "L" wire attached to some wire I extended through the firewall and attached to the brown wire at the idiot light and a ground wire running straight from the negative battery terminal, but the light doesn't power on when I turn the key on...
Only way I get the idiot light to power on once the key is in the on position, is if I have the "L" wire also connected to the battery stud on the alternator, but when the key is turned off, the idiot light won't turn off until I disconnect the wire...
