Thanks to everyone who contributed. Much appreciated. There are a few things I will change, several changes I wil consider and some new things I need to address. VVT/DOD, what would be the advantages of keeping as opposed to eliminating? I will likely go with the Holley engine and frame mounts as many members here and the LS site have good things to say about them.. I already have a Jeg's crossmember.
Anubis, I am keeping the 6L80. It is a heavy duty truck trans with a trans cooler that doesn't leak or slip. The SS is already not original and any changes made will be to enhance performance. I will do the trans tunnel right and not hack up my ride. If I have a 100% donor vehicle with the harness intact, what would be the benefit of making my own harness?
I will definately upgrade the valvetrain and have some "mild" head work done. I will have the money set aside for this swap and I want to do it righ before install and not be wishing I had done something when I had the chance. I'm still kind of second guessing the truck intake with the 75 to 80mm TB. Not sure of the exact size based on what I have been seeing. It does appear that an LS3 type intake would keep more power where I need it most so I will look at that option over a sheet metal intake.
Northernregal, good idea to reuse the truck fuel pump. I already have upgraded fuel lines. I have tentatively decided on a 2800 stall converter and will, at least do a shift improver kit if I don't have to rebuild the trans. I have never heard of Elgin cams. Since I am planning on doing some headwork would that cam still work? I am wanting to keep my power in the low to midrange primarily because that is where I'll spend most of my time with occasional wide open, high rpm runs.
Alot of good info and alot of things to consider and research. Again, thanks to everyone who has contributed. It helps to have experienced people to bounce ideas off of and keep me from stupid, costly mistakes.
