heres a pic of the first layer of resin:
it looks shitty cuz I had some resin that was a few years old and decided to use that. Its why you see the clumps on the flat parts, but no big deal here, it'll come off when I sand it in a day or two. I'm going to buy some high quality resin or maybe epoxy for the next two layers.
here's some fiberglass tips -
- some people like to put a layer of resin down and let it dry on the entire area to be fiberglassed before the cloth goes on, I've never done that but the idea would be for a better bonding surface for the first layers of resin.
- easiest way is to tack (or masking tape on the edges only) the cloth down, when the first layer starts to dry pull all your tacks/tape off
- first layer - just enough resin to wet the cloth, there should be dry cloth showing through in some spots, this is the biggest mistake for beginners is too much resin on the first layer. this layer is for giving you a structure to work with on the next layers (sand out any bumps)
- second layer - fill all the cloth you should see a little texture from the cloth still after it dries, some people prefer rollers here, it just depends on what type of surface youre working on (sand any large bumps after this layer)
- third layer - use a roller on this layer, this is where it should look like glass - no texture should show fromt the cloth, if it doesnt after this layer then you did something wrong. After this dries fill in any valleys with filler and sand down any bumps
... about the template, another mistake is people worry bout getting it perfect. Dont do this, is much easier to fill in with filler afterward than spend days on making your foam/wood/aluminum template perfect.
