I didn't use a torch to cut these springs.
and no one should be using a torch to cut a spring.....you need to keep the molecular structure of the steel consistent throughout the spring...
pontiacgp said:and no one should be using a torch to cut a spring.....you need to keep the molecular structure of the steel consistent throughout the spring...
When using an acetylene torch, the only brittle oxidized end is where you make the cut, it doesn't change the rest of the metal enough to factor in
pontiacgp said:and I suppose you have analyzed the metal to substantiate your post?....
I can't understand why anyone would want to use a torched to cut a spring in the first place, notwithstanding of the effect of the heat on the steel spring material, since it takes a few minutes to cut it with a hacksaw or a cutting wheel which leaves a nice clean cut and it has no effect on the molecular composition of the remaining steel ....
