No, it only cuts the flow off in A/C operation.Do you need The vacuum operated water valve to get defrost?
"The maximum recommended operating temperature for PVC pressure pipe is 140°F. " -GoogleMine has been taken out and the spliced the hose with a PVC piece.
That's interesting.Actually the hot water valve only cuts off the supply of hot water to the heater core in the Max Air position
That's interesting.
It also shuts off the fresh air and goes into recirc.
