Difference in rear sway bars.
LewG
20
Florida
Went to pick up a rear sway bar yesterday and had a choice of with or with out a hump so I bought them both. Does anyone know the different applications for each or more importantly which is better? It's going in a 86' Elco so I'm not going road racing but it will have a 500 Cadillac for extra push. With the shorter arms of the hump bar it seems like that bar would exert more force to keep the rear level. Any thoughts?
superbon54
755
2,440
Wisco
The shorter bar will exert more force because the lever arm is shorter. The mechanical advantage is significantly reduced with the arm mounted bars (vs a frame mounted) so if you’re looking to perk up the handling, I would go with the shorter one.
81cutlass
4,649
13,565
Western MN
The long arm one I have seen in 78-80's and the one with the "hump" for the differential is from 81+.
The early style one goes over the diff cover and the newer style one goes under, thats about the extend of the differences.
oldsmobile joe
2,067
3,053
mpls
i thought the long one was '78. all my 79 cutlass calais' came with the short style bar.
airboatgreg
2,870
3,116
I went with the hump on my 82 El C.
What a world of difference in handling. Well worth the coin
9,619
12,705
I have Hellwig sway bars on my Monte and I have always used the rears with the hump.
9,194
15,446
I thought the the long one was bigger diameter than the short. I have both, using the long one on the Monte, so I'll have to check that out later after I finish with the tree.
81cutlass
4,649
13,565
Western MN
Yeah that seems right, 78 for sure, I have seen a 78 slope back 442 in the salvage yard with one of the long arm bars.
9,194
15,446
I went out & measured both bars. The long one is .85", short is ."75. Only got the pic of the long, camara batteries died. My short came with the "new" frame ('86 SS) & the long I got in a junk yard off a Hurst/Olds about 25 years ago.
