Damn man what kind of nazi-land state are you in?!? :shock: Over here in NY my guy eyeballs my rubber, checks my lights and brakes, and plugs my car in to Albany. If there is a code, or the code was removed and not enough "good" cycles have occurred, I fail. OBD2 knows when you cleared the code, or unhooked the battery, and you cannot pass until the required amount of cycles has happened without setting the CEL. If no codes, I pass, just that simple. No one looks under the hood, or under the car, and I could have anything from a squirrel in a cage to a flux capacitor under the hood- no codes- no problem. So my CEL has been off since I used the O2 extension and the Tahoe also has no CEL since the cat cleaner was used. I'm not concerned.
