Glad you made it to the show ok. I ended up having other obligations so I could not go. Maybe next year. I have a couple questions for you. Does your vent deflector change a little bit with higher rpm? What are you running for pressure on low side of the A/C? I am thinking about getting a Ford vacuum pump to run the heating and cooling vacuum stuff. I do have check valves in, but the air deflector still closes a little bit at 2500 rpm and effects how much air blows out of the vents. I know you have overdrive, so maybe you don't have that problem.
Yeah my hvac doors change position when i go into boost. I don't have a check valve (I really need to get one) so when i go into boost it starts putting the AC on my feet. Another one of those things I havn't delt with. I have a vac canister somewhere, I just have to find it.
I think low side is 65 psi? I can't remember for sure. I have 4.5 cans written down for the cutlass and I put 4 cans in this and it cools plenty well.
