DYNO TIME
Congratulations. Cool car. If it isn't too much of a bother, post up a pic of the engine with the air cleaner off. I'm interested to see more of the fuel injection setup.
You around 500 crank HP and 450 crank ft/lbs - damn, those are great numbers. Better buy some extra tires for the rear.
I see alot of this in your future :
Thanks! Here ya go, this is the only one i have on my phone. Holley intake and throttle body. Holley. 48lbs injectors, and i have one of the holley in tank retrofit pumps. I ended up just going with all the Holley parts so I didn't have to worry about Compatibility issues. And surprisingly the only new parts were the injector rails, fuel pump and xmax system. I got the intake and throttle body used off marketplace and the injectors were floor demos from holley as well.
sorry for not adding that. running a 4L80E with shift kit
Good choice, all that is needed with that trans. I would have guessed around the 500 hp and 450 tq, nice numbers. Kind of the numbers flipped compared to most 455 builds.
Those coil covers set off the look 👌
Damn, that's some nice hardware. I wasn't aware of that multi-port throttle body intake. It's been since 2012 when we wrapped up our LS swap so some of the newer hardware has gotten past me. Maybe it doesn't make the torque of the truck intake but it looks great. I love the classic look of the 14" round air cleaner coupled with multi-port, electronic fuel injection. I also really like your coil covers. Thanks for the pic.
Thanks! i'm planning on getting another set and modifying them for a cleaner look, These were done for mock up and i cut them way too short. I'm wanting to cover the coil pack plugs too
