Well maybe you should re read as I stated I was wrong with my 1st deal I don't have have 900 worth of breaks its more like 600 again for me it was worth my point is don't knock others setups.tc1959 said:Like I said before use whatever works for your needs . If you need $900 worth of brakes to get what you need done then that's what you need to do. No worries :|Dave V said:tc1959 said:I didn't intend any criticism. just a case of sticker shock
I just did a 3/4 ton GMC 4X4 Rotors and pads and the parts were under $250
We use GM Durastop premium ceramic pads and Durastop premium rotors.
We also use Bendix titanium metallic pads and rotors None of the parts from our suppliers are anywhere near that spendy.
We also have found from experience that the EBC pads seem to be hard on the rotors , causing early replacement.
well i beg to differ i got over 10,000 miles on this setup and it works great and i find little wear on the rotors but it could be im usingt ebc rotors wihich are cad plated with slots and dimples like porchse rotors and with my pads. im glad you dont like spendy stuff i do i show this truck as well and to me it was money well spent stops on the dime everytime. and i just found my bill it was 613.40 shipped to my door pads front and rear were 167.00 and the rest was rotors which 432.00 plus shipping anyhow im happy with my purchase and id do it again. for elko im running autozone duralast ceramic pads with napa zince coated drilled and slotted rotors and it stops fine as well but when im towing 10,000 lobs i want to stop better then the el. good day all
els- said:Dave v, have you looked into the cryogenic rotors yet? Ive heard about them being used on hauling setups and doing good never drove with a set tho.
kornball426 said::shock: 800 bucks for pads and rotors did you do the calipers too?
That's a lot for just pads and rotors...
Phoenyx said:kornball426 said::shock: 800 bucks for pads and rotors did you do the calipers too?
Damn, I payed over $1200 for stock replacement (everything new except lines, booster, master cylinder, and proportioning valve from Budget Brake. 😢
You said it best the cheap rotors are always the issue that's why I got the ebc rotors for my truck454cutlass said:i have used ebc green stuff, mintex red and pbr metal masters. all were used on my audi and each were far greater than stock. the cheep rotors were allways a prob.
