It should still fit, pretty sure guys have ran it with the Qjet and 455 with a Performer in a G body which needs a 2" filter. He can probably use s 3" filter but it will be very close to the hood.
How about a 1" drop base with a 2' filter??
RPM is going to be even taller than the GM midrise I had on a sbc in my 78. Mine had no room for a drop base with a no choke horn Demon. Hadda cut a h o l e in my aluminum hood😢
Probably not soon enough for you. I'm dropping the engine at the machine shop tomorrow. So it will be a little while ( you know how it goes at the machine shop ). I have Edelbrock AVS 2 650 / Q Jet / Holley 750 vacuum carbs to choose from. I'm hoping the drop base w/ 2.5" filter will work. My body bushings will be new, so the car will sit up nice an straight also.You testing soon? Also, what carb will you be using?
A sbc is NOT an Olds V8, totally different. A 14" drop base is needed, you may need the 2" or 2.5" filter to clear. What are specs of your 350?That sucks. Thanks for info. Cutting isnt an option and if my set up wont allow it then I'll just stick with the A4. I'm ok with getting smaller cleaner and filter.
My 88 Cutlass Supreme Classic Brougham. As said, a 3" filter just clears on the later cars with the 1" drop base 14" air cleaner. Even if a 2.5" filter is needed, an air flow top can be used. There is some argument on where an Olds 350 benefits from a RPM intake. Some have gained at the track with a Vin 9 307, another 9 to 1 Olds 350 lost mph and ET track with the RPM over the Regular Performer. The A4, well any stock intake actually and Performer have a small plenum. I liked a 1" open spacer whether for a carb or the factory 454 to Qjet 1" spacer running TBI on the Olds powered 4x4. I am running a 1/2" thick open gasket on my 88 with the stock iron intake. I have the 1" open spacer on my Performer on my 70S.I know they are different. What year cutlass did you did you put the rpm intake on?
