Thanks for the shameless plug glad it's helpful!
I also recommend not using a return less setup. I have a return less setup on my fbird and have had issues. Besides running out of fuel pressure under boost and having to scale injector flow rates in the tune as manifold pressure changes you are also at risk of air locking the system. We had an issue where the car ran out of gas and we couldn't it started when refilled. I think the issue was air was stuck in the injectors and rails. The only way we got the problem resolved was when the fitting on the rail was removed so the air could get bled out.
