Elco won't start!
Vrummer43
n00b
Mar 2, 2019
4
My 1987 Chevrolet El Camino has been in storage all winter. It has been hooked up to a battery tender for most of it and I started almost every week. The past two Winters there has been mice in the car although no signs of them are currently present. Today, I turned the key in the ignition to start it, I heard a tick, then nothing. I tried several more times and got no response at all. I know it is not the battery, but have no further clues. Please help! Thanks in advance.
565bbchevy
G-Body of the Month
Aug 8, 2011
9,650
12,799
Michigan
Mice and other rodents really like chewing on wires which could be one issue.
Did you actually check the voltage on the battery,even though I think it was a fluke my buddies battery maintainer failed and killed the battery.
ssn696
Living in the Past
5,562
6,742
Permanent Temporary
Battery voltage? Below 12 and it may not have the juice to do more than pull in the solenoid -'click'.
565bbchevy
G-Body of the Month
Aug 8, 2011
9,650
12,799
Michigan
About 14.5V, if the guage is to be believed
A battery without an alternator charging it while running should be about the 12.7 volt range, I would get a volt meter and check the battery at the posts.
ssn696
Living in the Past
5,562
6,742
Permanent Temporary
Yes, that.
Max Headroom
420
389
It could also be one or more of several other things.
  • Corrosion on cable ends
  • Loose cable connection to battery
  • Loose ignition switch wire at solenoid
  • Bad Neutral Safety Switch (they do occasionally go out)
  • Loose ground to chassis or engine ( G Bodies check the alternator bracket. The battery ground to the engine was usually there)
Turbo Zach
2,534
5,875
You can have all kinds of voltage. Amperage is what does the work. That is why you test a battery with a load tester.
