I picked up the Spal 16" fan with all the wiring harness including the relay, it was installed but a car was scrapped before it was ever used. The descriptions says it is a pull fan but I would like to use it to replace the push fan that died instead of removing the pull fan I have now which has a higher CFM rating than the Spal fan to use as a push fan. I have looked at the fan and cannot figure out why I can't switch the power feed and ground lines to make it into a push fan. What do you guys think....This is the fan...
Thanks
Thanks
VA33-AP71/LL-65A * 16" P/12V | SPAL Automotive USA
www.spalusa.com
