Electric cooling fans
8,826
7,779
Melville,Saskatchewan
565bbchevy
9,616
12,688
Michigan
8,826
7,779
Also this
https://m.summitracing.com/parts/der-1683MobileSwitchYes#SwitchYes#
Or this
https://m.summitracing.com/parts/der-16927?ibanner=MobileSwitchYes#
I know the Derale fans were made in the USA and actually moved the air they were supposed to. I have used their relays with much less success, wires not crimped properly and fall out. Honestly buy a used set of Dodge Stratus dual fans and a good dual relay and temperature switch set up. With fabricated brackets, it fits the rad nearly perfect for a G body, move a lot of air and are cheaper new too.
http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=190590252712
565bbchevy
9,616
12,688
Michigan
454GrandPrix
429
818
Lehi, Utah
How do you mount the Intrepid fans since the mounting tabs are on the sides?
I am running dual 300M fans in my car. In my case, the bottom of the fan shroud "tucks in" snugly between the radiator core and the lower support. I simply attached two angle brackets at the top to bolt the shroud to the Cutlass upper mounting plate. These brackets only need to hold the shroud against the core; they are not supporting its weight at all and thus they aren't going to stress the shroud. If you look closely, you'll see I also did my usual trick of slicing some rubber vacuum tubing and slipping it over the edge of the shroud to ensure it doesn't harm the radiator core (and to provide improved air sealing).
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Nice!
DJHull
255
232
Lansing, Mi
Also this
Or this
http://www.ebay.com/itm/For-1995-2000-Dodge-Stratus-Chrysler-Cirrus-Cooling-Fan-2-4L-2-0L-L4/190590252712?fits=Make:Dodge|Model:Stratus&hash=item2c601076a8:g:1KAAAOSwPyBZqKjs
Also this
Or this
Excellent thank you. There are a lot of different manufactures at different prices. Some as high as $1000 for radiatorand fans.
Also this
Or this
DJHull
255
232
Lansing, Mi
Looks good. Love the silicone buffer. Great idea. Looks like you have plenty of room with the 454 in it.
DJHull
255
232
Lansing, Mi
Griffin Exact Fit Combo Unit Radiator Details
Vehicle: 79 Oldsmobile Cutlass
PART NUMBER: CU-00007Finish: Aluminum/Silver
Core Size: 26.38 X 18.53 X 2.68
2 rows of 1.25(in) tubing
Inlet/Outlet: TL/BR
Inlet/Outlet Size: 1.5"/1.75"
App Specific: GM "A" & "G" Body +
Notes: Some Models May Require 1.75" Lower Hose
Description: 1968 - 1977 Chevelle, 1964 - 1979 Skylark, GM "A" and "G" Body, Core 26.5 x 18.5, Manual Transmission - ExactFit - ComboUnit, Includes: Shroud, Fan(s), Wiring, Temp Sensor, and Rad Cap
Combo Thickness: 5.58 (in)
Fan Info: Twin 12 (in) 1722cfm
Shipping Info: Weight-35.00(lbs), Length-29.00(in), Width-17.00(in), Height-36.00(in)
