Hey friends!
Which of you upgraded from engine-driven fan to electric fans, and did not simply bolt the fans on the radiator, but went the professional way and installed a fan-shroud? And most importantly, what model/make can you recommend?
I am asking since right now, my Lemans has an OEM 3row copper brass radiator with two SPAL-fans bolted to it, biggest ones that would fit side by side. They move air like a beefed hurricane, but only on the surface where the blades run, so about 40-50% of the radiator doesn't get full airflow, especially since the "snout" of my Lemans isn't exactly airflow-friendly, as parts of the radiator are covered/blocked. On the picture you can see how it looks for now...
