sarends said:
EGR is not in play, from what ive been told.
Just look for yourself and see. The EGR valve should have 1 nipple for a vacuum line. The vac line that connects to this goes to the EGR solenoid ( black box on rear drivers side valve cover ). From the 'black box' a vac line goes to the proper port on the carb. The EGR solenoid should have a 4 wire connecter going to it.
If yours is different from this, it is incorrect.
The owner b4 me said it had factory duals but maybe hes wrong.
He is 100% wrong. There were NO true dual G-body cars. Keep in mind the former owner seems to have butchered up this car pretty good, so I would'nt believe a word he has to say about anything....
I havent checked the timing, i dont have a timing light. Ill have my father set it by ear, hes pretty good at it.
You need a timing light. Doing it by ear is a joke. If you do it by ear,it will be wrong because you're just guessing . A timing light is cheap or you can just borrow one from a friend. Time it with a light, get it set RIGHT, and eliminate it as a problem.
I have a Haynes manual but a whole lotta good they do. Ill do some more tinkering and see what it does.
You need a Chassis Service Manual like the ones the dealerships used. Take the Haynes and/or Chilton's manuals and throw em in the trash.
Since the previous owner butchered everything up, I would consider getting rid of the CCC system. If you do, get a Qjet because it's the best carb for your application and will bolt right in with no hassles ( assuming you get the proper Qjet ).
