CHRIS.O said:You have to get an HEI meant for an Oldsmobile. They have a different oil pump driveshaft than a chevy.
They also turn backwards from a chevy......
sarends said:There isnt a way to de-computerize my carb is there? Sounds silly i know but is it possible?
azmalibuwagon said:To try it out - If you disconnect the Throttle Position Sensor (driver side front, in front of the accelerator pump), the carb will just run full rich.
😀DoubleV said:azmalibuwagon said:To try it out - If you disconnect the Throttle Position Sensor (driver side front, in front of the accelerator pump), the carb will just run full rich.
Disconnecting the TPS does not make the carb go full rich. Disconnecting the Mixture Control Solenoid on top of the carb does.
DoubleV said:sarends said:The choke could be the problem but whenever it was idling up i unhooked the little plug for the choke and it didnt change. I went around that choke thinking it being unhooked and not doing anything when i crank the car, must mean it wasnt the problem. Is there a diagram of how its supposed to be hooked up somewhere?
When is it 'ideling up' exactly? When does it go back down?
What plug on the choke are you refering to? Do you have an electric choke? Remember the choke is more than just the flapper on top of the car. It's a whole system that makes your engine rev higher when the choke is on. You definately have at least some choke issues since you say it's always open.
Do you still have that big goofy vacuum diaphram on the front drivers side of the carb? That thing kicks up your idle during certain situations. Just remove it if it's still there since you won't ( or aren't ) be running the proper gizmos to make it work right anyway.
Pics would help greatly.
