My fault on the delay...I've been getting my pennies together. I finally narrowed it down to two different motors:
it's $1,000 cheaper. I do have a question for you guys though, if some reason I do get the L31, what's a good vortec intake to get with it, along with a cam? (model numbers please). Also, would the engine fit? I have a 2" cowl hood.
- L31 (12530283) Vortec/Roller Chevy Performance engine $1,827 shipped.
Nice to know I may have made a difference. The motor I built uses an Edelbrock EPS manifold. It is supposed to enhance the torque at 3500 RPM. I suggest this cam, as it uses the existing lifters and timing chain and is under the .460 lift limit for OEM Vortec heads: http://www.summitracing.com/parts/nal-14097395/overview/
I returned a chinese Weiand Warrior manifold - crappy casting - and paid a bit more for a USA-made Edelbrock.
The cam is $100 to $150 less than others, and being a roller, it can be reused/remarketed later if you decide to have the heads machined for more lift / stronger springs.
