You do mean 330 HP at the rear wheels, not at the crank?You need 330 HP to run in the 12.90's in a 3600 lb car.
If yours is a 305, everything will swap over.
Or you can reuse what you have. You can also piece everything together yourself from most suppliers. Alternator brackets to replace your existing ones are inexpensive. Stock power steering brackets aren't too bad to clean up and paint even if you can't separate the pump from the bracket. Hoses will be the same part number as the stock engine used.
If you can find a hot wire a electric fuel pump is not a big deal to install. As for the L31 crate motor and the cam listed you will have one heck of a motor. The set up is the same one GM sells as the 350 Ram Jet motor only it got a carb instead of the FI. I have the very same cam and motor in my bracket truck and it runs deep in the 14s with a th350 and a 3.42 gear. I might add the truck weighs in at 4,426lbs at the track. Not sure what the other motor is but I do know how this one performs for me. Should be one heck of a ride in a light weight ride.
Flywheel !!
Nows a good time to take off your pullies, alternator, brackets, ect. Clean them up, paint them, and cook them at 200 deg a couple times to get them really dry. It makes a really big difference in how long the paint holds up.
This is what my pile looked like last spring. Took a couple days between calls at work
