If the car doesn't run now and you want to do the clean up and painting yourself ahead of time then snap some pictures of the brackets before you remove them. For the most part though they're all old school small block brackets and most mechanics can figure them out easy. I wouldn't even re-install them. Let them cure and then store them in the trunk or something. I know when I pull an engine I take the accessories off first anyway.
I would also degrease and de-crud as much as possible before it goes to the shop. Unless they are willing to do it for you and agree to do it most shops won't clean the engine bay up. And it's just so satisfying to see a brand new engine in a clean engine compartment.
These things are where you can save labor costs and still get a beautiful result. Your engine bay looks like it would be an easy clean up. Just a little degreaser and scrubbing on the frame then some paint, and you can address the little bit of rust on the firewall without worrying too much about overspray. Hell get a hose and some detergent in there to, it's not like you're going to hurt the engine now. Just seal off the power steering cap and transmission dip stick.
I would stay away from the foaming Gunk brand degreaser, I used it and the regular during my last swap and the regular gave me much better results.
