Engine Mounts!!!
Your mounts will look like this. The Chevy mounts use holes that are farther forward than the Oldsmobile mounts.
The stickeyed threads in the engine swap section are excellent references.
http://gbodyforum.com/viewtopic.php?t=2485
Trick of the trade..Worked for me:1st Pull the hoses off the line (gives you more room).2nd Hit those (Drivers or Pass)Holes with a grind-more room.3rd😛ut black tape on a wrench with said nut in it and start the bolt from the top-alot easier.BTW a 3/8 drive+3" extension+swivel can get in from underneth.
trick of the trade ............... i just did the black electric tape to hold the nut on the wrench also.............. :lol:
