arent you the same guy that didnt know about the intake on the Buick V6 Megasquirt post
gutless supreme said:Here's one out of left field...
How about a newer 4.3l V6? The "high-output" version in the early 90s Astro/Safari was rated at 200hp and I'm absolutely positive you could buy an entire wrecked parts van with one for <$500 (then scrap it or part out the rest). Not exactly LS1 power, but it's more than a stock Monte SS and roughly the same as most TPI 305s - and it would leave you lots of money within your budget to improve on that. I'm pretty sure the version of that motor in your Monte only made like 130hp, so right off the bat that's a huge improvement... I briefly had an Astro with one of these a long time ago and it moved really well for it's size. Wiring should also be a lot easier since they're both OBDI, single injector systems. Should be able to retain your stock fuel pump and lines and most of the wiring under the hood will be - at absolute WORST - extremely similar.
I know someone just mentioned you can't legally swap a "truck" motor into a car in California... I'm not familiar with the CA testing process and how thorough it is at all, but if they're not looking for matching VIN numbers stamped on your block I don't see how they would even be able to tell. It would be near-identical externally and should easily pass the sniffer.
Nothing is quite like having a nice V8 under the hood, but for $1,500 you could easily get the performance of a stock 350 TPI (and then some) with better gas mileage... and it's a super easy swap!
