Engine tick or exhaust tick? - UPDATED
oldmansmonte
599
348
Buffalo, NY
So I changed the oil on the Monte. Let it run for about a minute and I revved it up to about 2,500 rpm when I suddenly heard a ticking sound.
Specs: Iron 350 w/vortec heads, flat tappet cam and lifters. Ceramic coated Flo Tech headers, split lock header bolts, 2.5 exhaust with high flow cats.
Oil: Amsoil Z-Rod 10w-30
Here is a quick video I made:
It's not real pronounced in the video. I don't believe it's on engine sound because it's more the less coming from under the car and radiating out. I replaced the collector gastkers in the spring. As you can see the flanges look a little warped. Also the headers were installed in 2011 with heavy duty gaskets and not touched since. I've noticed they've slowly gotten louder. Maybe they need to be tightened? Any thoughts would be appreciated.
Just listened on my ipad speakers a few times and it sounds like rocker noise. But not being there this is no real diagnoses for sure. On my speakers I hear the tick-tick-tick you mention. All you did was change the oil and then the noise? Again, on my end it sounds mechanical.
Good luck and I hope it is just some of the leaks you mentioned.
Thanks for the input. Yes, changed oil, revved up to 2,500 and the tick appeared.
Now I assume a rocker tick would be most noticeable under the hood rather than under the car though?
I tried tightening down the collector gaskets just for kicks. Upon further inspection it does appear to be a noise internally in the engine. Not piston slap or knock fortunately, it's definitely in the top end. Is it possible I damaged something from revving the engine after the oil change? It ran for at least a minute solid and yes a put 5 quarts in.
Anything is possible. The worst time for an engine is startup when everything is dry from what I have seen over the years.
When I do my oil changes my car had just taken a highway ride and the oil is very hot and I figured more gunk will come out in the oil change. Plus I figured the engine would not be totally dry because the parts would still have some old oil on them.
A good hint is if possible always put new oil in the new filter so you do not get a few seconds of no oil circulating. I know it is difficult when filters are sideways instead of up/down like chevy V8’s.
Hopefully it is nothing serious. Sometimes new oil can loosen some gunk and it might have circulated through?
Motor has 6k on it so imagine it's pretty gunkless. I feel like a fool for revving it that high just aftet changing the oil. It's possible it may have started before the rev and I didn't notice it. It could have even started during my last drive for all I know. I have a few friends that are mechanics that I'm waiting for them to get back to me. Hopefully it's just a rocker adjustment needed.
Easy enough, take off the VCs and check the lash on the rockers. Might be a stuck lifter or one that bleeds down for some reason while running.
I do my oil changes no earlier than 24 hours after the last run so make sure I get it bone dry. I I disable the ignition and just crank it over until I see oil pressure. Then I start er up, check for leaks, and be on my way.
Reactions: oldmansmonte
Hopefully running the valves will take care of it - Poly locks would stop the adjusting nut from backing off and if you don't have screw-in studs you might be pulling studs.
Do you have oil pressure?ive heard of brand new pumps being junk if not getting oil up there the lifters won't be able to pump up thus causing tick?
