I just installed a 421 sbc in my 88 Olds Cutlass. After breaking in the cam, running the engine at 2000-2200 rpms for 20 minutes, I went to adjust the idle speed screw to bring it down to idle. When I got to about 1500 the engine just cut off. When you squirt some fuel in by pressing the gas pedal twice and try to start it. It seems to try to start then nothing. While I was breaking in the cam and had the engine at 2000 rpm i the timing was at 25 degrees. After adjusting the idle speed screw I just can't seem to figure out why it won't idle. It is basically and new speed demon, I only had it on my previous engine a week before I bent a valve in it. I dumped the fuel out of the bowls before it was stored for a year or so. Any help would be great.
