Well, the freeze plugs came in and we got them installed. Had to pull the motor mounts and suspend the engine from the hoist.
After my dad put it all back together we took it down to the river and ran it on the trailer for about 15 minutes. Sounded and ran great! Temp and oil pressure was great!
Just one problem...water in the oil. Dammit.
The old man did all the work getting it out and on the stand. I went over this morning and helped him tear it down. Since we never found an obvious smoking gun, we completely disassembled it and he took the block and heads to the machine shop to be pressure tested. Should know more next week. They're also going to pressure test the intake and exhaust manifolds.
While he was working on that, I was doing a pretrip service on a guy's Winnebago. Gross.
Meanwhile, back at the ranch, the crew came up to bury the electrical conduit from the box up to the house. They also carved out for the footings at the low side of the basement.
The next scene was almost comedy. We called the guys who dug the well years ago about whether or not the existing pump would be adequate to push water to the top of the hill. They suggested doing an output test. Since we weren't seeing useful numbers, they volunteered to come out and test it properly. First thing they found was a defective pressure gauge. In the process of replacing that they managed to crack the brass manifold. Well, sh*t. After they replaced that they discovered that the bladder was ruptured and the tank was waterlogged. sh*t, sh*t! Now I have a new tank too.
Since I was gone when they finished up we still don't know if the pump is up to the task or not.
Now we wait for concrete.
