BUILD THREAD #FamilyBurnoutWagon (1983 Malibu Wagon)
151
190
Las Vegas, Nevada
Rebuilt the Holley carburetor and modified it to better handle the boost from the Weiand Supercharger.
151
190
Las Vegas, Nevada
#FamilyBurnoutWagon gets blown!! Check it out!!
151
190
Las Vegas, Nevada
I have a few more #FamilyBurnoutWagon videos I need to add here.
Firstly, rivnuts are legitimately an awesome thing you can add to your project. I didn’t get paid or endorsed by anyone to make this. I just really think they are that good.
Second, if you need more adjustment on the secondary part of a vacuum secondary car, I have the answer. With very little effort you can add a metering block to the secondary side which allows you to swap different jets in. Fast and simple. Check it out.
151
190
Las Vegas, Nevada
I made some updates and repairs to the #FamilyBurnoutWagon and then we went to the drag strip to test out some slicks and fail. Check out the video here:
ssn696
Living in the Past
5,548
6,679
Permanent Temporary
Lockwire. Because racecar. Good call on the end-curl. No need to leave random razor blades lying around...
I like the ownership montage. Challenger trying to stay in-frame.
151
190
Las Vegas, Nevada
Lockwire because aircraft mechanic. It's like aviation's duct tape. If I was smart I would have drilled a hole through the other nut and lock wired them together.
I'm hoping to have a little better run this winter. Maybe I can have a number I can be proud of with a torque converter that stays locked up under power, a bit more boost, colder temps, and a lot more driving skill. Something that starts with a 13 would be a good start. Although, I was proud of putting away all those late model cars. Even with my terrible driving.
Most importantly, Thanks for watching the video!
151
190
Las Vegas, Nevada
My beater wagon achievers Drag Racing GLORY!! . . .at least in my eyes. . . | #FamilyBurnoutWagon EP16
With the new converter I hit the loose goal I laid out in the previous post.
ssn696
Living in the Past
5,548
6,679
Permanent Temporary
151
190
Las Vegas, Nevada
The #FamilyBurnoutWagon got some love. I have figured out how to get the "LS Brakes" emergency brake to work with the GBody cable. Also, I am really happy with the Caprice springs. Check out the video.
